Will anything happen if i remove the air
Old May 23, 2003 | 05:34 PM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
Im going to put a transmission cooler on my car but i saw that the airconditioner radiator(cant spell) is in front of the radiator so i thought why not just remove it i dont use my air any ways so i was wondering if i could remover my airconditioner radiator and just leave the pump and all the other airconditioner stuff on because i dont want to have a radiator with 2 other things in front of it.
THANKS
Old May 23, 2003 | 05:47 PM
Vader's Avatar
TB,
As long as the condenser coil is clean (no debris sticking all over it) there should be no air flow restriction, and therefore little benefit from removing it.
Old May 23, 2003 | 07:00 PM
tbfirebird's Avatar
Engine: ??????????
Well little here and there helps my car im going to take it out anyways just to lighten up the front end and little bit easier to get to the fittings on the trans cooler and little little bit more air flow.
Thanks for yor help though.
Old May 24, 2003 | 09:55 AM
Vader's Avatar
If you don't already have the transmission cooler, you could try using the condenser as an oil cooler. It will tolerate the pressure, and should flow adequately.
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
