intermittant no start
Old Sep 11, 2000 | 11:25 AM
JWS's Avatar
JWS
when my motor gets hot(above 200 or so), if I shut the car down and wait a few minutes, then go to turn the key to start, nothing will happen. No click, nothing. I'm able to jump the starter soleniod with a jumper wire, so the starter is good. Has anyone else had this problem and solved it? If it's not the solenoid wire, what else could it be?
Old Sep 11, 2000 | 12:33 PM
dan's Avatar
dan
Make sure the ground are all good and clean and intact. Weak grounds can cause this.
Old Sep 11, 2000 | 12:39 PM
perp's Avatar
my dads old 87 Iroc would do this. He changedt he starter tryign to fix it and nothing would fix it. He eventually ran a bump start switch from his battery to the selonoid.
Old Sep 11, 2000 | 12:43 PM
T and A's Avatar
I had this exact smae thing happen to me, and believe it or not, All i had to do was tighten the connecton at the battery, and it stopped happening. i dont hnow why it did it olny when it was hot.
Old Sep 11, 2000 | 12:46 PM
FJK's Avatar
FJK
What kind of car is it? Does it have a VATS system? If so, check the post close to yours for" Car won't start-Help"
Old Sep 12, 2000 | 12:25 AM
SDC's Avatar
SDC
Sounds like starter heak soak to me. My 92 Formula had this problem and tried virtually anything. Then I pulled the starter. My starter actually showed signs of warping. Plus if its the original starter and you have over 100k, its probably just plain worn out. I've noticed that after 100k f-bodies start having some starter problems. Luckily starters are pretty cheap. Though it would invest in a heat shield.
-Sean Casey
92 Formula-350
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
CORV3TT3
Aug 23, 2015 11:26 AM
92camaroJoe
Aug 13, 2015 06:07 AM
