Do I need a cam button?
Old Sep 12, 2000 | 12:56 AM
Mike '91 Z28's Avatar
I'm in the proccess of doing a heads and cam swap. I have a hydraulic roller cam that is going in. My question is, do I need a cam button with a roller cam? thanks for your help.
Old Sep 12, 2000 | 02:18 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I believe you will. Hydraulic and solid lifter cams have a slight angle to the lobes to turn the lifters in their bores and prevent wear. This has a side-effect of pushing the cam to the rear. Roller rockers have flat lobes and so don't have this effect.
Old Sep 12, 2000 | 07:47 AM
novadude's Avatar
If you have your stock '91 block, there is a thrust plate on the front of the block behind the cam gear that retains the cam. A Cam button will be necessary if you are putting a roller cam in a non-roller (pre-'87) block though.
Jorlain
Oct 8, 2015 01:57 AM
Elephantismo
Interior Parts Wanted
Sep 24, 2015 05:15 PM
Strick1
Sep 4, 2015 07:11 AM
luvofjah
Sep 3, 2015 07:08 PM
masonta
Sep 1, 2015 06:40 PM
