700r4 to tubo 350 swap
Old Jul 20, 2000 | 11:20 AM
chevy2ss's Avatar
Car: 63 Nova SS, 91 Camaro Rs
Going to do this swap on a friends car.Its a 85.What all is involve ?Is it a direct bolt in(minus shifter and cooler lines).What i'm most concerned about is the bar that goes from the rear to the trans.Any help would be very much appreciated.Thanks in advance
Old Jul 20, 2000 | 11:41 AM
Dr. Pepper's Avatar
That bar is called the torque arm. B&M as well as hurst has kits to mount the needed bracket on a TH-350 or TH-400. I know the B&M kit also takes care of the cross member mount location difference. A few people have made cross members and torque arms that work together to take the stress off the transmission. While nobody seems to have trouble with the stress on the transmission its not a bad idea. If the TH-350 has a 9" tail shaft you will be able to use the same drive shaft. Otherwise you may have to get a new drive shaft or have the old one lengthend. You probably already know that you need a different torque converter and dip stick for the TH-350. You will also need a different detent cable for the TH-350. Overall once you have the torque arm mount for the TH-350 its not a hard swap.
Old Jul 23, 2000 | 01:44 AM
rhuarc28's Avatar
Why bother though? the 700r4 is a pretty good trans stock as long as you don't go crazy with the power, and the turbo 350 will really screw your gas milage
Old Jul 23, 2000 | 04:19 AM
beattie1175's Avatar
Check out SPOHN Performance. They make an excellent torque arm/ crossmember unit. Bit pricey, but worth the investment if building big power.
Old Sep 12, 2000 | 11:55 AM
brockrodgers's Avatar
Car: YTG Camaro
Engine: 383
Transmission: TH-350
I did the same swop. One word of advice if you use the B&M kit make sure to get longer bolts for the tail shaft mount. I didn't and lost 2 bolts and it made alot of noice. The treads were not engaged enough and pulled out of the transmission. The bracked is thick and therefore you will get less thread engagement. Go for the swap if you dont like OD. The R4's are just way to wimpy!
'84 Camaro 327ci Bored .030 over w/ 5.7" stroke. 3.73 geared Auburn Limited Slip Diff. FlowMaster Muffler w/ Shortie Headers. TH-350 Built Trany Underneath B&M Mega-Shifter. Many Engine compartment Dress Up Mods. Edelbrock High Flow Water Pump w/ Flex-a-Lite Cooling Fan.
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
camaro11j
Sep 19, 2018 08:49 AM
bellez77
Sep 5, 2015 08:39 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
