Piston to valve clearance
Old May 26, 2003 | 12:57 PM
OMINOUS_87's Avatar
Well I will be getting around to checking my piston to valve clearance in the next couple days and it just dawned on me that if I dont have proper clearance I am screwed!!!
Here is the setup:
383 with 5.7 rod and zero decked block.
.041 gasket
KB 12cc dish piston
Comp XR276HR 224/230 .537/.545 with 1.6 roller rockers
E-tec 170 heads with 64 cc chambers 1.94 intkae 1.55 exhaust valves
What do you all think??
Old May 26, 2003 | 05:35 PM
ede's Avatar
ede
if you have a problem with the clearance doesn't mean you're screwed, you correct for it. as a rule you will never have problems untill around .65 lift, with out a gasket, but it's always wise to mock things up and check.
Old May 26, 2003 | 08:53 PM
Damon's Avatar
I am familiar with those particular pistons. THey have a DEEP "trench" on the edge of the D-shaped dish. You will likely have NO clearance issues.
Old May 27, 2003 | 12:35 AM
OMINOUS_87's Avatar
Damon
Did you do a buildup with these slugs? If so what were the specs of the setup?
Old May 27, 2003 | 12:57 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
It's not likely this engine will have a problem, but you should check valve to piston clearance anyways. Sometimes the valve clearance notches aren't exactly in the right spot under the valve.
I just assembled my 360 with .015" deck clearance, .015" head gasket, 4 eyebrow flat tops, extremely shaved big valve 305 heads nd a cam with much more overlap and valve opening at and near TDC and I had just enough.. (.093" at 0 lash) intake valve.
The exhaust didn't even come close the the piston.
Old May 27, 2003 | 02:16 AM
OMINOUS_87's Avatar
Here is a pic of the valve relief. Let me know what ya think.
Old May 27, 2003 | 10:16 PM
Damon's Avatar
Ominous- my setup was a 383 stroker and used heads with 2.02/1.60 valves and a much less aggressive cam than yours. I had MILES of valve-piston clearance.
Just remember that clearance problems happen during OVERLAP between the exhaust and intake strokes when both valves are slightly open, not at max valve lift (when the piston is half way down the bore).
Always best to check with some clay and mocking up the assembly temporarily, but I'd be REAL surprised if you have clearance problems.
db057
Apr 28, 2019 07:45 AM
New2Chevy
Sep 28, 2015 12:35 AM
355tpipickup
Sep 13, 2015 11:35 PM
Nick McCardle
Sep 10, 2015 08:36 PM
