Plug Wires - Need set w/all 90's
Old Sep 12, 2000 | 07:34 AM
Mike 25th's Avatar
Does anyone sell a direct replacement plug wire set that has all 90's instead of the three straight boots. I have SLP headers and the straight boots are useless. I don't want to have to buy two sets either...
Someone has to have them...
92 Z28 - 5.7 - Black/Grey Leather
Macewen White Faced Guages
SLP T-RAM, 24lb/h Injectors
Accell 52mm Throttle Body
SLP 1 3/4" Headers and Cat Back Sys.
Old Sep 12, 2000 | 07:54 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
After my multi-angle MSD's turned to crap within 1 month, I replaced them with the off-the-shelf Advance Autoparts plug wires. They all fit with my headers, and all of the boots are 90*. They were only $18 too
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Sep 12, 2000 | 07:57 PM
89ProchargedROC's Avatar
Well, i like my MSD's. i bought the universal set where you make your own set. very easy to use and came with everything you need to do the job. Best part is the custom lenght, every engine is different, especially when headers are involved.
Old Sep 12, 2000 | 08:10 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Accel makes a set with all 90s. BTW, they also make header spark plugs that are shorter so they clear headers better.
1983 Pontiac Firebird SE
LG4-Based Chevy 400
700R4 Tansmission
Modified 4 Barrel Q-Jet Carb
Accel Super Stock 8mm Wires
Edelbrock Pro-Flo Air Cleaner
3.23 Posi Rear
14X7" Cragar SS/T Wheels
35X4 CD/AM/FM Head Unit
100WX2 Amp
2 Pioneer 12" Subs in Custom Box
Old Sep 12, 2000 | 10:57 PM
Steves ZZ5's Avatar
There is also the Accel 300+ universal plug wires. (Black wires with faint yellow writing 8.8mm). These are about $58 through Summit or Jegs. I went with these on my 86' with headers after i burned through a set of standard Accels.
Good luck,
86 Trans Am WS6 Black with tinted windows, shaved door handles
ZZ4, Mini-ram, true duals
***Too many other mods to mention***
"In the future, cities will become deserts,
roads will become battlefields, and the hope of mankind
will appear as a stranger"
The Road Warrior
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
apo_bailon15
Mar 28, 2016 05:20 AM
