Why does my car overheat so much?
Old Sep 11, 2000 | 08:39 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I finally fixed my Air conditioner, and now i cant even use it much becuase it makes my car overheat. I installed a heater control valve a while back, but that doesnt seem to help. I think maybe my thermostat is stuck shut, and i also think my fan clutch is worn out. What can I do to lower my cars temp?
1983 Pontiac Firebird SE
LG4-Based Chevy 400
700R4 Tansmission
Modified 4 Barrel Q-Jet Carb
Accel Super Stock 8mm Wires
Edelbrock Pro-Flo Air Cleaner
3.23 Posi Rear
14X7" Cragar SS/T Wheels
35X4 CD/AM/FM Head Unit
100WX2 Amp
2 Pioneer 12" Subs in Custom Box
Old Sep 11, 2000 | 08:42 PM
ede's Avatar
ede
replace your t-stat and fan clutch and see where that gets you.
Old Sep 11, 2000 | 09:43 PM
Fat Elvis Z-28's Avatar
I once had a car that I bought new, and I took good care of. The radiator pluged up for no reason that I could see, but it fooled me for a long time. I would take the cap off and look in and see coolant flow in the top levels but I finally put my hand down lower on the core and it wasn't nearly as hot as it was on top. No flow down low. New radiator problem gone.
Old Sep 11, 2000 | 09:44 PM
Old Sep 11, 2000 | 09:46 PM
Old Sep 11, 2000 | 10:10 PM
formula90's Avatar
Car: 1990 Formula
Engine: 5.7 liter
hey fat elvis...dont make it so obvios that you are building posts we heard you the first time!!
I have experience...unfortunatly,its a result of bad judgement.
click below to check out MY FORMULA PAGE!
http://www.members.tripod.com/~Astra...uild/front.htm
or click below to email me
Astralbaby@webtv.net
Old Sep 12, 2000 | 12:35 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
definately check that your airdam is intact and sturdy, thats the peice that hangs down from the radiator and seems to scrape on alot of things (provided you have it)
Old Sep 12, 2000 | 01:03 AM
Ski89Z28's Avatar
When does the car overheat? City or Highway driving?
Do as Pablo says and recheck you timing with can cause overheating if out.
Check for anything blocking the radiator such as leaves or paper.
If the stat is closed, you think, then start the car remove the radiator cap and see if the fliud in the radiator is moving. If it is then the pump is good and if the fliud in the radiator gets hot the stat is good.
The radiator cap could be bad, this happen to me, and city driving I use to over heat and highway I was fine.
Hopefully this might help, I hope.
Good Luck!
89 IROC 350 Auto
TRUE DUAL Exhaust
Edelbrock Performer Aluminum Heads
ZZ9 Cam
TPIS Level 5 Chip
Old Sep 12, 2000 | 10:22 PM
bowtieguy01's Avatar
do what i did and manually wire your fan to a switch and flick it off and on at will.
Old Sep 12, 2000 | 11:05 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
well, for one he has a engine driven fan, so a fan switch isnt gonna help. definately replace your fan switch. especially if the problem is downtown low speed driving. onthe other hand, if you are having trouble with highspeed cooling also, check your air dam and replace it if it needs it, 15-20 bucks i think from gm. also i would suggest replacing your thermo also if u havent done it rescently... throw a 185 or 180 in it, you wiull be much happier with the cooling!
Steve
88 Firebird Formula- deseased 2/9/99- 305 TPI, SLP 3 inch exhaust, SLP Intake runners, SLP cam, 3.45 BW disc brake posi, WS6, NOS, and all that good stuff, 13.~ sec 1/4 mile- hit by what else!?!? a FORD EXPLORER!!!!!!
86 Firebird, LG4, t-tops, slp 3 inch exhaust, catco cat, and a bunch of new/replaced stuff, open element, soon to come, 2 inch cowl hood, 3.42 posi disc rear from a 4th gen, and hopefully a 6 speed!
My Webpage- Battle of the birds, My own Thirdgen Page, still under construction, http://www.geocities.com/soares711/index.htm
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
