Ignition problem and O2 sensor
Old May 27, 2003 | 06:03 PM
flyway190's Avatar
Could an ignition problem that causes unburnt mixture to run through to the exhaust cause the oxygen sensor to indicate a rich condition?
Old May 28, 2003 | 05:58 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I suppose so; the computer would probably try to lean the a/f mix out, but if the ignition was that bad, the computer might not be able to adjust enough. How do your plug electrodes look? Did you pull one (or a few!) and check them out?
db057
Jan 10, 2020 08:55 PM
gta892000
Aug 11, 2019 11:16 AM
HoosierinWA
Oct 7, 2015 10:15 AM
Racerx974
Sep 19, 2015 10:16 AM
BLK87Z
Sep 18, 2015 11:29 PM
