Mr. Woodruff...please Step Inside
Old May 27, 2003 | 11:15 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
i need a .184x.680 woodruff key for my crank snout...every place i went to only had like 5/16x2 or whatever
i bought an assorment of keys the sizes are
3/32x1/2
1/8x1/2
5/32x5/8
1/8x3/4
3/16x3/4
whichi one of these will work?..and how is it supposed to fint in the slot on the crank?, like just sit in there or is it a tight fit?
Old May 28, 2003 | 05:24 AM
ede's Avatar
ede
i've got them from my machine shop before. might want to try a industrial supply, like mc master-carr or granger, maybe even a tractor supply store.
Old May 28, 2003 | 07:56 AM
Damon's Avatar
It should be a modestly tight fit. Should have to tap it in lightly with a mallet.
Note that most SBC cranks use a key that is half-moon shaped. Flat on the top, rounded on the part that goes into the crank keyway. There are 2 identical ones- one for the timing chain lower gear and one for the balancer.
Old May 28, 2003 | 09:12 AM
Vader's Avatar
Originally posted by Damon
...Note that most SBC cranks use a key that is half-moon shaped. Flat on the top, rounded on the part that goes into the crank keyway....
That would be a Woodruff key...
Old May 28, 2003 | 11:16 AM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
will do ede..thanks
damn what did i do to have 2 mods post in my thread woooohooo lol
Old May 28, 2003 | 06:00 PM
Damon's Avatar
Just thought I'd throw that in in case anyone thought you could shove a Home Depot square-cut key in there.
Linson
Oct 24, 2025 02:00 PM
Gunner242
Dec 25, 2015 04:49 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
KO1
16
Oct 15, 2015 05:00 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
