engine code breakdown
Old Sep 12, 2000 | 09:20 PM
Get Blown ?'s Avatar
I just got a good look at my engine and the numbers 627 are cast on both sides. Anyone care to tell me that that code breaks down to? I've been wondering what's under my hood for sometime since the previous owner claimed it's a newer/rebuild 305. But I never trusted the crooked SOB.
My car is the perfect women. She's braless, won't talk back and loves a good beating.
1989 Camaro RS L03 w/ WC T-5
http://350.StreetRacing.org
ICQ: 61342629 AOL IM: BlackSunshineZ28
Old Sep 12, 2000 | 09:57 PM
Vader's Avatar
GB,
Are you certain it isn't "327"?
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Sep 12, 2000 | 10:07 PM
Maybe, I could have swore it was a 6 though...Me being upside down swapping my plugs didn't help any reading it. So what exactly does that mean? It doesn't mean there could be a 327 under the hood right?
[This message has been edited by Get Blown ? (edited September 12, 2000).]
Old Sep 13, 2000 | 11:34 AM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Get Blown?, you are originally right, it is 627, as in 14093627. That is a 305 block for 1988-94 models years. Typically in all SBC have the last three numbers of the block casting number (or P/N) are stamped on either side of the block for easy reference. From my knowledge, GM (or should I say Chevy) never put the CID on the block (or sides), this is because the CID is based on the crank which was not specific to a block. Example: A 657 block was equipt with a 3.00", 3.25" and 3.48" crankshafts for 302, 327, and 350 CID engines (respectfully).
George P. Lara
1994 Z28 LT1 T56
1984 Z28 High Output
Member: SCCA, SCFB, SC3GFB
[This message has been edited by MRZ28HO (edited September 13, 2000).]
Old Sep 13, 2000 | 03:21 PM
Just got another look at it today it's definitely 627. Probably is the original block then since it smokes a little on startup. Just gives me more reason to rip it out.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
