I need input on fuel delivery.
Old May 28, 2003 | 01:45 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Well, I've got a 305 TBI.
I will be swapping a rebuilt 350 shortblock from a 70s truck sometime soon.
This engine will be mildly built with Vortec heads, Comp XE268H cam, and Edelbrock Performer RPM Air Gap manifold.
I want to know which is the easiest way to fuel it.
I have a spare holley 670cfm and carb adapter in the garage.
I'm wondering if it's worth my time to find someone to burn me a PROM.
I definitely DON'T have time to learn myself (unless it's as easy as you people make it out to be).
I don't own a laptop, either.
I don't really WANT to swap to carb, but I will if it's easy...
Which it looks like it's not, considering i need an AFPR and distributor etc.
This car will be my daily driver with exception to the winter.
Here are some questions I have.
[b]1) What's the easiest method in my case to fuel my car?
2) Can I learn how to burn my own PROMs in a few days?
3) Will the car even run okay with a stock PROM or do I *have* to burn it?
4) I've heard two different stories with the stock dist... can you use it or not?
I'm stressed out over this. I want to get my swap ready and done with. Thanks.
Old May 28, 2003 | 08:31 AM
ede's Avatar
ede
cheapest and easiest thing to do would be to swap the induction system to the 350 along with all the sensers and computer controls.
Old May 28, 2003 | 02:04 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
how would it run though, with the stock ECM?
Old May 28, 2003 | 03:32 PM
Vader's Avatar
With the correct injectors (350 TBI Caprice or truck) and correct EPROM in the ECM, it should run just fine.
Old May 29, 2003 | 12:15 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
such as, with an L05 EPROM it will be just fine?
or do you mean custom tuned?
Old May 30, 2003 | 10:17 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
bump, thank you
midge54
Dec 27, 2019 04:14 PM
italiano67
Dec 11, 2016 09:21 AM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
