Startup Smoke
Old Sep 12, 2000 | 07:24 PM
IrocLouver's Avatar
Startup Smoke
My '90 IROC, 5.7, smokes at startup and is getting worse daily. There is a good amount of oil at the head/intake manifold interface on the passenger side, and some on the other side. Question is: can a bad intake gasket cause startup smoke? I don't think it is the valve oil seals because of the rapidly worsening conditions, and the fact the car has only 34K miles. Thanks.
Old Sep 12, 2000 | 08:02 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
I still wouldn't rule out the valve seals. Those are notorious for going out like that. 34K miles or not, could be age in conjunction. Intake gasket? I don't think so ... oil doesn't pass through the intake. That leak is most likely your valve cover gasket. Also Check your PCV Valve and breather ... one or both can be restricted. I'm still willing to bet on valve seals. **** poor design on GM's part.
[This message has been edited by Allan (edited September 13, 2000).]
Old Sep 13, 2000 | 05:21 PM
Camaro91S's Avatar
Car: 91 Camaro RS
Engine: 350 C.I.
Transmission: 700R-4
I have a 91 RS, mine does the same thing. I asked my mechanic buddy what the hell it was and he said valve seals. Oh well, just make sure nobody is standing behind the car when you crank it up.
91RS305TBI
FormulasOnly
Jul 23, 2018 08:47 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
KCG
Sep 23, 2015 09:05 AM
Accerrito22
Sep 5, 2015 09:34 PM
