Power Pulleys
Old Sep 11, 2000 | 05:18 PM
Garmer's Avatar
Power Pulleys
What is the best brand out there that will not make you loss any amp power?? And how much should I spend on a set? Is a 2 or 3 peice better?
91 RS Camaro
3.1L
Cat Back System, K&N filter, Fastchip Stage 2, 160 thermo, Rapidfires and Bosch Wires
CD Player
Old Sep 11, 2000 | 05:52 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
IMHO their all junk, charging problems, especially in traffic, and cooling problems in the hotter summer months.. any gains from pulleys is so minute their about pointless, youll notice a better gain from a thourough tuneup.. most dyno sheets show pulleys to only be good for 1-4 hp..
Old Sep 11, 2000 | 07:50 PM
Garmer's Avatar
Has anyone had any luck with a street car?? If not I guess they are not worth it!!
91 RS Camaro
3.1L
CD Player
Old Sep 11, 2000 | 08:52 PM
rondubbs's Avatar
get a march 2 piece pulley set,, its cheap and its a mod that adds up with other little mods. if your that worried about charging get the power and amp set.
Old Sep 12, 2000 | 03:53 PM
Garmer's Avatar
Is it true that the hp increase is only about 4 hp?
91 RS Camaro
3.1L
CD Player
Old Sep 12, 2000 | 05:11 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
the power and amp set underdrives your crank and gives you a larger alternator pulley.. making any gain even less.. i tried a 3 peice set and was very upset with my purchase, i managed to sell them for close to what i paid tho.. i dont remember where i saw the dyno sheet for power pulleys, but im sure you could find it if you searched...
Old Sep 12, 2000 | 05:29 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Let me add a little mechanical knowledge to this thread. First off, if you underdrive your crank pulley (got to a smaller diameter) then you need to underdrive (go to a smaller diameter) your alt pulley as well to keep your charging capabilities as designed. If you just get the underdrive crank pulley your crank/alt pulley ratio just went down, which means your alt needs more rpms to fully charge. If you get both underdriven and the sizes remain relative to each other, you will maintain your crank/alt pulley ratio. I believe the reason some of you are quick to say they are junk is because you got an inferrior pulley set. scoob800, you mentioned you got a smaller crank and larger alt pulley, your ratio went from good to real bad (I don't know the ratio for serpentine setups, but I can double check multi-belt systems). What you should get is a smaller crank and alt pulley, then you wouldn't have charging problems. Hope this brings some much needed light on the subject.
George P. Lara
1994 Z28 LT1 T56
1984 Z28 High Output
Member: SCCA, SCFB, SC3GFB
Old Sep 12, 2000 | 08:43 PM
Garmer's Avatar
But what are the HP gains??
91 RS Camaro
3.1L
Cat Back System, K&N filter, Fastchip Stage 2, 160 thermo, Rapidfires and Bosch Wires, soon to come: Homemade Ram Air, and maybe headers and power pulleys
Old Sep 12, 2000 | 09:07 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
well, in my buds tbird, we did an elcetric fan switch over, and pulleys, his amps are ok, and he prob gained about 15 hp. he is now faster than me, where as before those mods he was slwoer...
Steve
Old Sep 12, 2000 | 09:31 PM
Kevin G's Avatar
I dont think you will get 15 h.p. from changing your pulleys......IMHO they are not worth the hassle. Maybe 4-5 h.p. tops.
94 Z28-M6 S-Trim
-=ICON Motorsports=-
Old Sep 12, 2000 | 11:10 PM
IROCKZE's Avatar
Car: 85 Mercedes 500SEL
Engine: 5.0 DOHC
I have heard 2 tenths in the 1/4 from pulleys, but also that you can't feel any SOTP increase. I have the March 2 piece crank/alt set, and only have the alt on right now. So who knows, I guess every little bit helps.
85 IROC,tpi,t-tops,fully loaded,black with red l/s "camaro" interior,91 Bose system, Fastchip,TES,AFPR,K&Ns,92 police 700r4
"The devil drives a Camaro"
Old Sep 13, 2000 | 11:20 AM
fb305svs's Avatar
hey here is some cold hard facts. that 15hp that i said my bud prob gained was from the combined mods of the pulleys and electric fan conversion. These changes made a NOTICABLE change, not just a seat of the pants. an d engine fan on the dyno for our race motor was worth 8 hp when we took it off...
Steve
Old Sep 13, 2000 | 12:57 PM
rondubbs's Avatar
i believe march claims a 10hp increase at the rear wheels!!!
Old Sep 13, 2000 | 02:25 PM
Garmer's Avatar
If I dont get pulleys what should my next mod w/o touching the engine yet??
91 RS Camaro
3.1L
Old Sep 13, 2000 | 03:30 PM
Get Blown ?'s Avatar
I don't know about Camaros, but I remember reading on MustangWorld or SN-95.com they gained close to 15hp on a 96-98 GT with March power pulleys.
Since we're talking about under drive pullies, I think there's a set on my car. MAC is stamped on my crank pulley. Don't know if that's OEM or MAC brand. (do they even make pulleys for Camaros?)
My car is the perfect women. She's braless, won't talk back and loves a good beating.
1989 Camaro RS L03 w/ WC T-5
http://350.StreetRacing.org
ICQ: 61342629 AOL IM: BlackSunshineZ28
Old Sep 13, 2000 | 04:29 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
garmer, got a k&n air filter yet? if not, theres a good first mod.. in most cases you will notice a gain.. one of the best gain/price mods, if you even wanna call it a mod, it really isnt.. if you really wanna lower your reciprocating mass (ie pulleys, faster engine acceleration), go for an alluminum driveshaft, tho they arnt cheap..
Old Sep 13, 2000 | 05:11 PM
Garmer's Avatar
scoob look at my sig to see what I have done so far!! When I did my K&N, I also took off this stupid side route piece, I could really tell the difference, and you could hear and see the filter sucking in the air!!
91 RS Camaro
3.1L
[This message has been edited by Garmer (edited September 13, 2000).]
Old Sep 13, 2000 | 05:38 PM
MRZ28HO's Avatar
Engine: was: L69
GB, yes it is a MAC pulley, they have pulleys for 86'-'92 TPI. Go to MAC's website and see for yourself.
[This message has been edited by MRZ28HO (edited September 13, 2000).]
Old Sep 13, 2000 | 06:32 PM
That also explains when idling it gets about 12.5-13 volts vs the 13.5 it should have. For those who are wondering my car runs fine. No dead battery here. knock on wood
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
sailtexas186548
Aug 24, 2015 10:11 PM
Navy8125
Aug 22, 2015 07:13 PM
Street Lethal
Aug 12, 2015 11:33 AM
