RPM's used in Valve adjustment?
Old May 28, 2003 | 06:01 PM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
What are the RPM's (preset at idle) used in a valve adjustment procedure for good results? Or no problem with this? (2.8 l V6 engine).
Thanks for the help.
Denis V.
Old May 29, 2003 | 05:22 AM
ede's Avatar
ede
idle
Old May 29, 2003 | 07:55 PM
NickyCamaro's Avatar
In the Chiltons book it says how to adjust them when the car is not running. I have set valve lash (adjustment) about five times and I always do it like this and I get good results. I have been told multiple times you can only do it like this on a fresh set of lifters with no oil in them...they are full of s. My only warning should you decide to do it this way, is that you follow the directions very, very, very, did I mention very, closely. If you don't understand somthing repost or don't bother to try it this way. Oh yeah and if you are running roller fulcrum rockers only turn go 1/2 to 3/4 turn after the pushrod can no longer be spun.
deracer
Apr 11, 2016 12:04 AM
db057
Sep 4, 2015 07:57 AM
86IROC112
Aug 21, 2015 07:20 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
