Adding tach to LG4- "Tach terminal" question?
Car: 1986 Firebird
Engine: 2.8 V6
I have a friend with the LG4 motor, and we're putting a tach on it today.
He has the coil-in-cap HEI distributor.. is that "tach" terminal easy to get to? Does it take a female quick-disconnect connector?
Or do I splice into a wire somewhere? I had to splice into a wire on my remote-coil HEI setup, I'm not quite sure of the "proper" hookup for his '86.
Thank you!
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Thank you!
Car: 4
Engine: 6
Transmission: 5
It just plugs right in. It is a regular ¼" female quick-connect slide. It's best to use an insulated one so it doesn't short to the BATT terminal, which could blast the module.
Car: 1986 Firebird
Engine: 2.8 V6
Cool, thanks for the info, as usual I appreciate it!
ProtoMaster22
Aug 26, 2015 07:50 AM
