How much HP with this setup?
Old May 29, 2003 | 11:52 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
I am getting a set of 91 z28 l98 heads for dirt cheap to replace my swirl ports. I will probably do a mild valve job and port and polish to the heads.
I am getting a lt4 camshaft OR extreme energy 264 grind cam. Depending on what I do to the heads.
This will be on a 9.6:1 compression 350 roller motor. I have edelbrock TES headers with a 3'' hooker catback with no cat.
For induction I have a holley street dominator intake and a 670cfm holley street avenger carb. (may be going with a regular 600cfm holley)
would this put me close to 300hp?
Old May 30, 2003 | 07:22 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I think you'll do better with the Comp cam than the GM one.
600 CFM is to small. The 670 would be a better choice. A slightly larger carb would probably be an even better choice.
300 HP is not unreasonable for that setup. With careful work to the heads, you may get more than that.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
