Oil filter boss bolts?
Old May 30, 2003 | 02:28 PM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
Anyone know what size bolts I need to hold in the oil filter boss (the part the oil filter screws onto)? Thanks!
Old May 30, 2003 | 02:34 PM
ede's Avatar
ede
1/4-20, not sure of the length
Old May 30, 2003 | 02:46 PM
Scott_92RS's Avatar
Car: 1992 RS
Thanks! Should I buy black oxide or any type of special coating on the bolts? Any lock washers required at all? My engine was dissassembled years ago and I've since lost the bolts for it, and dont remember anything about them.
Old May 30, 2003 | 06:49 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I think they're about 1". Factory ones have a washer head IIRC. No special treatment as far as plating or any of that is needed; after all, they're immersed in oil 100% of the time. If you use regular bolts, use flat washers with them.
Old May 30, 2003 | 07:01 PM
Scott_92RS's Avatar
Car: 1992 RS
Yea, I figured that since they were in oil, any decent bolt would be fine. Thanks for the info guys!
Old May 30, 2003 | 07:16 PM
boogie's Avatar
If you want the OEM bolts, 3951644 is the GM part #. $0.95 each
Old Jun 1, 2003 | 08:57 PM
Scott_92RS's Avatar
Car: 1992 RS
Thanks! Is there any kind of gasket that goes between the boss and the block?
maroe624
Apr 16, 2017 08:29 AM
Derick15
Sep 17, 2016 05:28 PM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
