Charcoal Canister?
Old Sep 14, 2000 | 10:47 PM
NOSFEDGTA's Avatar
Charcoal Canister?
My car is no longer smog legal. It has no cat, smog pump or egr. If I take out the charcoal canister will I have any codes or problems? and what all has to be done..? anything special I should know about? or do I just take it out and remove the wires and vacume lines going to it?
Old Sep 15, 2000 | 01:31 AM
formula90's Avatar
Car: 1990 Formula
Engine: 5.7 liter
yes. also you are s.o.l. if you top off your tank cause that is where the fuel ultimatly goes although that is not the purpose of th canister. why do you want to remove it since it is connected to the fuel return vapor lines?
I have experience...unfortunatly,its a result of bad judgement.
click below to check out MY FORMULA PAGE!
http://www.members.tripod.com/~Astra...uild/front.htm
or click below to email me
Astralbaby@webtv.net
Old Sep 15, 2000 | 07:28 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I've had mine off for over a year with no problems. I removed it because I plan to run dual batteries and I need the space.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Sep 15, 2000 | 03:50 PM
NOSFEDGTA's Avatar
Did you cap off the fuel lines running to it ? and what did you do with all the vacum lines and elecrical wires?
Quzyle
Oct 15, 2015 03:35 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Racerx974
Sep 19, 2015 10:16 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
TBRays98
Sep 6, 2015 05:05 PM
