wtf? troubles replacing fuel filter on my 305 HO
Old Sep 12, 2000 | 06:53 PM
Skeletor's Avatar
I cant get the fuel line to unscrew.. i sart bending the fuel line.. so i got got two wrenches on it.. and about a gallon of WD40.. zero luck..
and of course its on a carbed motor. quadra-junk carb..
84Z28 5.0 H.O.
litely moded up
Old Sep 12, 2000 | 07:37 PM
Vader's Avatar
Skel,
Normally, I'd suggest some heat on the fittings, but that will have an obvious disadvantage in this case. You may need to apply penetrating oil over the course of several days to allow enough time to penetrate the threads enougn to get the filter free. Another thing that can help is shock or impact, but it would be far to easy to crack the die cast carburator body in this case.
Anyone else?
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Sep 12, 2000 | 07:47 PM
Skeletor's Avatar
Who said this was gonna take me 10 mins?
i suppose if nothin else i could take it in somewhere (profesionally) do it.. but for a $3 part on a job that SHOULD take 10 mins..
whats a good penetrating oil? besides WD40.. ive been dumping that crap on there all evening..
Old Sep 12, 2000 | 07:56 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
PB Blaster ... about $4 a can at local auto parts stores. I swear by it!
Old Sep 12, 2000 | 09:41 PM
T and A's Avatar
Skeletor, go to the store and buy a can of rust penetrator/inhibiter, and spray the snot out of the screwed on end. Wait about 15 min, get a line wrench and a cresent wrench, andtweak it off. Hope that helps.
Old Sep 12, 2000 | 10:13 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Best Stuff I've ever used is from GM calle Heat Valve Penetrant. Works on everything pretty quickly.
Old Sep 12, 2000 | 11:08 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
i had the same trouble. what i had to do was get a special pair of vice grips, the pair that holds nuts on 3 sides ( ) and use that cuz the small fiting was loose. then i put a big wrench on the filter housing and kept that tight while i yanked on the pair of vice grips... what a pain in the *** , i will be switching to mostly rubber line soon, so i can put an inline filter in and a carb spacer.
Steve
88 Firebird Formula- deseased 2/9/99- 305 TPI, SLP 3 inch exhaust, SLP Intake runners, SLP cam, 3.45 BW disc brake posi, WS6, NOS, and all that good stuff, 13.~ sec 1/4 mile- hit by what else!?!? a FORD EXPLORER!!!!!!
86 Firebird, LG4, t-tops, slp 3 inch exhaust, catco cat, and a bunch of new/replaced stuff, open element, soon to come, 2 inch cowl hood, 3.42 posi disc rear from a 4th gen, and hopefully a 6 speed!
My Webpage- Battle of the birds, My own Thirdgen Page, still under construction, http://www.geocities.com/soares711/index.htm
Old Sep 13, 2000 | 11:13 AM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Never ever use vise grips or pliers on the hex nuts! Try tapping it with a metal object (not banging, just hard tapping) and some penetrating oil. Also please, please get yourself some closed wrenches with the cutout (specifically for tubing nuts), I believe you need 5/8" and 11/16" (or 3/4"). Sears has a complete set for like under $40.
George P. Lara
1994 Z28 LT1 T56
1984 Z28 High Output
Member: SCCA, SCFB, SC3GFB
Old Sep 13, 2000 | 02:56 PM
Skeletor's Avatar
no vise grips or plires? oops. heh. ok i wont try to use those anymore.. and i have been tapping on it.. im thinking about getting a big hammer to bang on it.. it wont help me at all, but it makes me feel better
what i'll just do besides get proper tools, just keep dumping penetrating oil on it.. i'll be back in a few days if i still have problems.. like a broken fuel line cause i used the hammer idea.
Old Sep 14, 2000 | 04:26 PM
Rileys85Z's Avatar
PB Blaster!!....you will never buy another can of WD-40.
Old Sep 14, 2000 | 05:38 PM
fb305svs's Avatar
well, i was assuming that the nut was already stripped as mine was. the 3 sided vicegrips do not squash or strip the hex nut how ever.
Sorry about that! u SHOULD use a set of fitting wrenches on any type of a fitting however!
Steve
Old Sep 14, 2000 | 06:30 PM
Kevin G's Avatar
PB BLASTER RULES!!!!!!!!!
Old Sep 15, 2000 | 05:29 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
And use some anti-seize on the fittings and inside the inverted nut when you reassemble everything! It'll save you some grief next time...
Pete
Pete's Place
Now at HiOutput.com
83 SC...LG4/5-speed from an 84 Z28, 3.42 one-tire-fryer, T-tops, PW, PH, gray interior from an 86 Firebird SE, seats from an 89 Formula, Wheels from an 83 Z28, springs and rear bar from an 84 Z28, WS6 front bar, Hedman Hedders and y-pipe, Dynomax cat-back, .420" lift cam, Accel HEI Supercoil and foam air filter, custom air induction through Z28 hood.....best ET is 14.935@94.14
92camaroJoe
Jul 29, 2023 07:57 PM
specialized
Jun 18, 2022 09:26 AM
bryan623
Mar 22, 2021 06:43 PM
Brcharrelson
Aug 26, 2015 07:47 PM
92camaroJoe
Aug 13, 2015 06:07 AM
