New track results for L69
Old Sep 11, 2000 | 08:46 PM
84305HO's Avatar
Car: 84 Z28 Camaro
Engine: 350ci
Went to the track a few weeks ago with following mods over what is in signature:
1.6 roller tip rockers, Al driveshaft, and
aftermarket LCA's. Did I get a surprise!
No traction! The LCA's really stiffened up the rear and the car did not squat like last year at the track. First run 15.5 @ 93 w/2.5
60ft, second 14.9 @ 95 w/2.5 60ft. Last run
babied it off the line and went 14.52 @ 96.24
w/2.27 60ft. I am happy that the car is making some good power(for a stock 305) but wow I really need to do something w/traction.
Presently installing Spohns relocation brackets and looking into some shocks for the
front........ My goal is to have a stock 305
in the 13's !
Any advice or suggestions is welcome.
Tom K.
84 z-28 M5 305 HO
pulleys,coil,3:73(stock)
Jet StageII, fan switch
14.55 @ 95.02 2.15 60ft
[This message has been edited by 84305HO (edited September 11, 2000).]
Old Sep 12, 2000 | 01:31 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
in the 13's !
I have a l69 I would like to run well a only a few bolt ons. Do the 1.6 rockers bolt up with no modification alot of people say no? Thank you for any help. I ahve a trans am 30,000 original miles L69 it seems to run really strong but I have never had it at the track. Kevin
Old Sep 12, 2000 | 02:50 PM
84305HO's Avatar
Car: 84 Z28 Camaro
Engine: 350ci
kjgroen, Comp Cams 1.6 roller tips just bolted in with no modifications to the heads.
Tom K.
84 z-28 M5 305 HO
Old Sep 12, 2000 | 03:29 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Originally posted by kjgroen:
I have a l69 I would like to run well a only a few bolt ons. Do the 1.6 rockers bolt up with no modification alot of people say no? Thank you for any help. I have a trans am 30,000 original miles L69 it seems to run really strong but I have never had it at the track. Kevin
Kevin, only when you use full roller rockers do you need to use tall valve covers with perimeter style heads. Other than that, there are no modifications. Even if you use 1.6 ratio rockers on stock springs, rocker studs and camshaft, you will have no problems. The .030" increase in gross lift is ~1/32" of an inch (not much to the eye). Larger aftermarket cams can present a problem that could require upgrades.
Tom K. (84305HO), knock it off, your making my setup look bad. sigh I wish I still had my L69, but I am thinking of rebuilding a roller 305 short block, to replace my current short block, and mock the L69 with a hotter roller cam, ported W/P TQ'er 305, Weiand manifold, 1-5/8 headers but still with my 700-R4. I think if you add 1-5/8 headers and a cat-back you should be close to 13s, if not break 13s. How "stock" do you want to have, long block stock? BTW, any thoughts on running street slicks or drag radials? Congrats and good luck.
George P. Lara
1994 Z28 LT1 T56
1984 Z28 High Output
Member: SCCA, SCFB, SC3GFB
Old Sep 12, 2000 | 08:13 PM
84305HO's Avatar
Car: 84 Z28 Camaro
Engine: 350ci
Thanks George, since I cannot find an adjustable front shock that I can live with
on the street I think the next move should be
either headers or a sticky tire. I am leaning
toward the tires because I still have the all
original (16 yr old) exhaust in good condition (w/gutted cat).
Tom K.
84 z-28 M5 305 HO
Old Sep 13, 2000 | 12:15 AM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
Damn thats impressive, nice to know that
people support the 305, it's a good motor,
that properly moded can really scoot.
I've heard great things about the World Products S/R torquer heads.
Old Sep 13, 2000 | 02:07 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I just had a new best 1/4 mile time with my lg4 of 13.5 @ 99.5MPH. I have lots of mods but the bottom end of the motor is untouched with about 115K miles on it. Take a look at the mods in my signature. High or mid 13's are possible with stock pistons but you will need some good flowing heads, sticky tires, and exhaust work.
84 Camaro 305 ported & milled heads, 3 angle valve job, Edelbrock Performer RPM intake, Hedman full length headers, Accell ignition, Crane 274H cam, B&M 700R-4, 3000 stall speed, 4.10 gear,
M/T ET street tires
visit my website at http://www.geocities.com/jbenge/page1.html
Old Sep 13, 2000 | 03:50 PM
84305HO's Avatar
Car: 84 Z28 Camaro
Engine: 350ci
Jbenge, what kind of 60 ft time did you have with that run ? That is a great time!
Tom K.
84 z-28 M5 305 HO
Old Sep 13, 2000 | 10:28 PM
crazyjoe's Avatar
Hey Tom, what were your 1/8th mile times on those runs? I wanna compare my times with yours on the 1/8th, because that's all we have in this area. Thanx.
'91 TA, 305TPI, mild cam, stock heads ported and polished, ported plenum, SLP siamesed runners, edelbrock TES headers, flowmaster 3" cat-back, 3.73 posi, K&N, custom CAI, hypertech stage II chip, march underdrive pulleys,
"305 my A**" -countless mustang owners, after a good spanking.
Old Sep 15, 2000 | 06:05 PM
84305HO's Avatar
Car: 84 Z28 Camaro
Engine: 350ci
1/8 mile for the good run was 9.39 @ 76.10,
the other runs.........Yuk
Tom K.
84 z-28 M5 305 HO
Old Sep 15, 2000 | 09:32 PM
crazyjoe's Avatar
Damn Tom, that is impressive, the best I could do with my 305 was a 9.608@72.2. That was before the ported plenum and runners, and the custom cold air induction. Havent had a chance to get her back to the track yet. Still, not too bad for stock 700R4, with 180,000 miles on it, and it's an automatic! Rock on, fellow 305 brother!
Bubbajones_ya
Oct 25, 2015 08:01 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Oct 3, 2015 01:25 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
