what kind of power should this setup make?
Old Jun 1, 2003 | 01:38 PM
bad_ta_05's Avatar
Car: 85 trans am
Engine: 79 4 bolt 350
i have a 79 350 from an old truck. i am installing ported 305 heads with bigger valves and a 3 angel valve grind, edelbrock performer intake, cam (unknown what cam and valve springs i am going to use yet, will be calling comp cams to see what they recomend), 600 cfm electirc choke edelbrock carb, 14 by 3 inch air cleaner, and flowtech headers and y (i know they suck and will be replaced in the next year by hooker or hedman headers) and it will go into a cutout and then through a stock 305 exhaust (will be replaced in a year or so by either duals or a 3 inch flowmaster cat-back. car has a stock posi rear end (dont know what gears) and a rebuilt 700r4 tranny with stiffer 2nd gear and a vette servo. torque converter is stock i think, i dont know what the tranny guy put in it but i am guessing its the stock converter. so what do you guys think? what kind of power will i be putting out? will it be close to 300? thanks alot.
Old Jun 1, 2003 | 02:47 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
kinda hard to say without details like cam specs and if that 79 truck engine has been rebuilt or if its still stock and if it was rebuilt what pistons were put in it etc.. do you wanna know what kinda power it will make at the wheels or at the fly wheel? i'd say 300 rwhp is sort of a long shot..
Old Jun 1, 2003 | 02:49 PM
bad_ta_05's Avatar
Car: 85 trans am
it was rebuilt, it has about 32,000 miles on it at the moment and i dont know what kind of pistons were used, i will find out when i pull off the heads. what cam would you guys recommend? i dont really want to change the converter so im not sure what i need. thanks
Old Jun 1, 2003 | 02:51 PM
89RsPower!'s Avatar
if the car is able to run start it up and see where the converter stalls at.. should at least give ya good estimate
Old Jun 1, 2003 | 03:16 PM
bad_ta_05's Avatar
Car: 85 trans am
this is probably a stupid question but how do u know where it stalls at? im hoping to make about 250-300, someplace around there. flywheel or rear wheels, doesnt matter to me as long as its there. thanks
Old Jun 1, 2003 | 03:47 PM
89RsPower!'s Avatar
put one foot on the brake and one on the gas and see how high you can get the rpms without the tires braking loose, that should give you a pretty decent indication of the stall
jhawkeye
May 25, 2022 06:33 PM
onefreakz
May 14, 2018 12:15 PM
db057
Aug 22, 2015 08:17 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
novaderrik
Aug 10, 2015 12:44 PM
