Black smoke
Old Sep 14, 2000 | 01:38 PM
Andy 91GTA's Avatar
Car: 91 GTA & 92 GTA & 92 GTA
Engine: 305 TPI & 350 TPI & 350 TPI
Axle/Gears: 3.42 & 3.23 & 3.23
Black smoke
I drive a 91 GTA with a 305 TPI with 4 speed auto. When my car sits for awhile and I start it up, a puff of black smoke comes out of the exhaust pipes. From reading GM Service Brochures and this message board, it is due to an overly rich fuel mixture. I would appreciate it if anyone could tell me what the cause(s) of this is. Thanks.
Old Sep 14, 2000 | 02:27 PM
dan's Avatar
dan
It could be a leaking injector, I guess. Are you sure it is not a bluish oil burning smoke, which would be the valve seals and posibly worn valve guides.
Old Sep 14, 2000 | 02:47 PM
Andy 91GTA's Avatar
Thanks for your input. I'm positive that it is black smoke. My mechanic said that a fuel injector pressure test could be done to see if any were leaking. I just wanted to see if anyone else had an idea about what could cause this.
Old Sep 14, 2000 | 02:58 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
You could have a bad coolant temperature sensor. This will tell the computer that you're like -500 degrees and it will rich the crap out of the car when it starts. My firebird riched out so bad that it would flood and not start.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Sep 15, 2000 | 08:44 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Andy, if it's black smoke only in the morning when you first start your car, it is most probably a leaking injector(s). Does it run rich any other time besides extended starting intervals?
If you have a problem,
If no-one else can help,
And if you can find them,
Maybe you can hire....
THE A-TEAM
Old Sep 16, 2000 | 07:45 PM
Andy 91GTA's Avatar
To my knowledge, there is only black smoke when I start the car up, occasionally, its not bad, but I want to get it fixed. I will probably get a fuel injector pressure test next week to see if that is the problem. Thanks for the posts. If anyone thinks it could be anything else let me know.
Old Sep 16, 2000 | 10:33 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
If it doesn't smoke when you get on it, or after quick stops, I would say the problem is with a leaking injector(s).
gta892000
Aug 11, 2019 11:16 AM
Stryker412
Sep 20, 2015 06:59 PM
m00n420
Sep 11, 2015 02:39 PM
Accerrito22
Sep 5, 2015 09:34 PM
Out-Cast
Canadian Region
Sep 4, 2015 10:13 AM
