valvr stem seals
Old Jun 2, 2003 | 02:57 PM
Chesty3131's Avatar
Car: 91 Z28 conv
valvr stem seals
Do I need to remove the heads to replace the valve stem seals?
Old Jun 2, 2003 | 03:04 PM
ede's Avatar
ede
no, guess i really ought to ask heads on what, but if it's a SBC no
Old Jun 2, 2003 | 03:06 PM
Chesty3131's Avatar
Car: 91 Z28 conv
valve stem seals
How would I keep the valves from falling in? The engine is a L98 on a GTA.
Old Jun 2, 2003 | 03:12 PM
Chesty3131's Avatar
Car: 91 Z28 conv
valve stem seals
any help would be greatly appreciated.
Old Jun 2, 2003 | 04:20 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
use cmpressed air to hold the valves up in place. use around 100 psi in the cylinder.
Old Jun 2, 2003 | 04:28 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Put the piston at TDC and stuff the cyl full of about ¼" rope.
Old Jun 2, 2003 | 09:43 PM
KNTA4DNU's Avatar
Car: '97 Z28
Engine: 5.7
Transmission: M6
I did the "rope trick" on my 4.3 S-10 engine last weekend. I pulled all the plugs so I could turn the engine easily by hand. After the first two I gave up on trying to figure where the piston was and just stuffed rope in until it wouldn't take any more, then hand cranked the engine until I felt some resistance. This technique works really well. Just make sure you have a LONG piece of rope. Depending on the diameter of course, you might be surprised how much can fit in there if the piston is down the bore a bit.
I used a $15 Sears valve compressor. The procedure that worked best for me was to remove the spring and leave it in the compressor tool. Take off the old seal. Install new umbrella sleeve (if your using them). Put the compressed spring back over the valve stem. Slide the new "O" seal on, using a tiny screwdriver to manipulate it into the lower of the two grooves on the valve stem. Install the locks (a little grease will help hold them in place) and release the spring tool. Oh yeah. VERY important. Cover any holes in the head with a rag while you are working. Dropping one of those locks into the engine could ruin your day.
Old Jun 2, 2003 | 11:05 PM
jimmy_mac's Avatar
If you do have a compressor, the hose on your compression gage can be used to screw into the spark plug holes. unscrew the gage from the hose and the shrater valve from the other end.
Old Jun 3, 2003 | 05:27 AM
ede's Avatar
ede
make sure the compression gauge doesn't have a check valve, mine from sears does, my snap on don't.
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
