What are the biggest valves you can put on a 383?
I think that you can put larger that the 2.02/1.60s on a 383, right?
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES Headers, Hooker Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Components, K&N Filters, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.3 @ 97mph
L98 TPI 350 (5.7L)
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
You can only go upto 2.05"/1.65". Beyond that you are shrouding the valves. Theoretically you are supposed to go to a max. 53% intake and 41% exhaust based on the bore, and typically 50% intake and 40% exhaust.
George P. Lara
1994 Z28 LT1 T56
1984 Z28 High Output
Member: SCCA, SCFB, SC3GFB
[This message has been edited by MRZ28HO (edited September 13, 2000).]
George P. Lara
1994 Z28 LT1 T56
Valve size is limitted to the head, not the engine. If you want to dump about $15,000, GMPP makes a 14* sqlayed valved head (simular to the BB head) it has 2.3" intake vavles.
My AFR 210's have 2.08/1.6. Many aftermarket high performance SBC heads under $2500 have 2.18".
The runner size and flow is what you should be looking at.
210s? Wow, what size engine do you have?
L98 TPI 350 (5.7L)
L98 TPI 350 (5.7L)
