removing engine
Old Jun 3, 2003 | 01:13 AM
BluEyes's Avatar
removing engine
Is there any way to pull an engine from one of these cars without removing the front grille/fascia?
I've got one of them nice engine hoists, and from the front it puts the hook about even with the waterneck, and going at an angle it's still several inches away from even the closest hole on the lifting plate.
Is it possible to pull the engine with the hoist not centered over the engine? (no, right?)
Old Jun 3, 2003 | 01:50 AM
1986redbird's Avatar
man, I don't know what kind of lift you got but mine will reach almost to the windshield when it's fully extended. make sure the lift arm is all the way out to its furthest setting and it should work, I pulled the motors out of two "birds" and never had a problem.
Old Jun 3, 2003 | 05:25 AM
ede's Avatar
ede
my lift, and every other one i've seen or used would reach to back of the engine if not farther, sure you have it adjusted out as far as it'll go?
Old Jun 3, 2003 | 09:25 AM
jimmy_mac's Avatar
ye, and not just the top arm with the hook. The legs extend out also. Most have bolts on the legs securing them through a welded on nut. The top arm should have a hole with a bolt going throug it. Make sure you have the legs out enough to support the amount the top arm is extended.
Old Jun 3, 2003 | 10:35 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
No kidding. I overlooked that little leg extention when I was pulling the engine off my stand (getting ready for installation). As soon as I picked the engine and stand off the ground there went the back of the hoist in the air. Had to have the wife stand on it until I could get everything rebolted to the stand and the legs extended.
Your boom should extend. I haven't seen one yet that doesn't.
Old Jun 3, 2003 | 05:20 PM
BluEyes's Avatar
yup, the boom is all the way out, the legs are on... Won't reach
Just tried going in from the side, but the legs hit the tire, and I can't even get close enough that way!
BTW: it's a "Team Mechanix" hoist... Sux, bought it a year ago when I thought I was going to rebuild the motor on my '77, but time/money didn't work out then, and I think it's a bit late to take back now. Just took it out of the original cardboard boxes, too - all shiny and new. Maybe I'll try and sell it? I got a deal originally and paid about $200, so I might be able to recoup that, maybe... Then just build an arch to go over the engine and pull from above with pulleys...
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
perZ
Aug 15, 2015 01:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
3rdgenparts
Aug 8, 2015 07:09 PM
