Problems
Old Jun 3, 2003 | 10:05 AM
Fred91TA's Avatar
Car: 1991 Trans Am
Transmission: 4L60
Problems
I understand this isn't the cooling board, but I want to try to keep this here so I can get a quick response. The other day, my radiator sprung a big leak. I got a new 2 row radiator from Radiator Barn. It went in with no problem and took me 30 minutes tops. Now I have a problem...either the temperature gauge is malfunctioning, or my temperature gauge not malfunctioning and is pegging out to the right over 260* after a drive around the block. Has anyone else had this problem? Do I need to reset or adjust something?
Old Jun 3, 2003 | 10:30 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
You shouldn't have to reset or adjust anything. Is your T-stat working properly? Kinked hose?
Old Jun 3, 2003 | 10:38 AM
Fred91TA's Avatar
Car: 1991 Trans Am
Transmission: 4L60
Thanks for the prompt reply. I solved the problem. I didn't have enough water/coolant in there. I started it up, added another GALLON of distilled water, drove it, and voila...no over heating. :lala: Funny how that works, huh?
Old Jun 3, 2003 | 12:53 PM
Vader's Avatar
Check it again in a couple of days or so. All water contains entrapped air. As the water heats, the air is driven off, creating a bubble in the system. If you're really ****, you can pre-boil the water to deaerate it as much as possible and minimize this phenomenon, but it's a good idea to check it periodically anyway (as in at least monthly), with all the rest of the fluids, belts, tires, lights, etc.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
