V.a.t.s Help!!
Old Jun 3, 2003 | 04:38 PM
paul5.0's Avatar
Car: trans am 1991
V.a.t.s Help!!
I can not find a resistor to by pass my passkey vats anywhere!! I tried all the local electronic stores. I have a code pellet 6 or 1.47 value ( 1470 ohms ) key. I know how to bypass but I cant get this resistor. The guy at radio shack said a 1.5 resistor will do fine, but what does he know about the GM VATS system. Help
Where can I get one???
Will 1.5 do?
Should I just get a new ignition switch???
92rsv8 I tried to email you but your box is full. Thanks for your help.
Old Jun 3, 2003 | 05:02 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Delete VATS in the ECM/PROM. Then it wont matter what resistor you have or dont have in your key.
Old Jun 3, 2003 | 07:07 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Get a 1Kohm resistor and a 470ohm resistor.
Wire in series, (end to end) not parallel (on top of each other).
You now have a 1470ohm resistor
Shakoba
Mar 10, 2015 10:05 AM
TheHog91
Apr 22, 2012 09:28 AM
JMR
Oct 9, 2009 01:36 PM
