Cam and computer not matching up???
Old Sep 15, 2000 | 10:30 PM
GilmourD's Avatar
My father was checking out my car and noticed that it's running very rich. He thinks it's because of the cam that was installed by the previous owner (which I don't even know what it is). My father said that it's because the computer thinks the stock cam is in there, and running the engine as if that were so. What do you guys think? I'm pretty sure it's a Crane cam, but I'm not sure which one. I haven't taken the engine apart, since this is my daily driver and I don't have a day or two to do that.
What do you guys think? Is my dad just a crazy old man, or is he right? LOL And if so, how the hell do I fix that?
1986 Firebird, LG4 305, bored .040 over, Crane cam, Edelbrock headers, Hooker Aerochamber muffler, loud and fast.
"Gimme fuel, gimme fire, gimme that which I desire!" - Metallica, "Fuel"
Old Sep 16, 2000 | 02:42 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You probably just need to adjust your carb, and/or make sure your mixture control solenoid is working.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Sep 16, 2000 | 10:56 AM
crows_camaro's Avatar
I know someone who had a bigger cam put in and it cut off at about 60
when he put in a chip it was all better
Old Sep 17, 2000 | 11:36 AM
GilmourD's Avatar
So... Would it be adjustments to the carb I need or a new chip?
Old Sep 17, 2000 | 01:42 PM
Blade's Avatar
Adjust... a chip aint gonna do **** for you. Go to a junkyard and look for a bunch of cars that have the Q-Jet as your car. Get all their secondary rods and hangers. Then go home and try each of em on with different combinations. I forgot how it goes, but I think a higher letter hanger is richer and also thinner rods give you more gas. So in your case I guess u'd want some fatter rods, generally a lower two letter combination like AA or AE...
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires...
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Old Sep 18, 2000 | 09:04 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
It has nothing to do with your computer not liking the cam. CCCS doesn't care what you put under it, it will work.
If it's just running rich all the time, i vote for a bad/misadjusted TPS. Very common problem, and generally doesn't throw codes. If it isn't that, then it could be anything (except the chip itself which is definitely fine.)
Don't listen to crow either. A chip will not cure any problems with a CCCS car. Cut out at 60....yeah right. The stock timing curve isn't that bad that it will cut the engine out, and a chip does not affect WOT fueling whatsoever.
There are some posts about the TPS on teh carb board now (pretty sure anyway.)
...ed
Orr89RocZ
Apr 25, 2016 08:28 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
theurge
Aug 21, 2015 12:46 PM
Bryan F
Aug 18, 2015 02:28 PM
matthew911
Aug 12, 2015 09:38 AM
