Ignition timing
Old Jun 4, 2003 | 10:37 PM
maxx's Avatar
Ignition timing
Does the ignition timing change when you take a stock 305 and rebuild it as a 335 stroker?
Would the ignition timing still be 0 degrees btdc (before top dead center) or would it change?
305 is 0 degrees
350 is 6 degrees
I would think the 335 would change, would anyone know what it is or how to find out what the ignition timing should be?
Old Jun 5, 2003 | 12:12 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Base ignition timing is set by you and has nothing to do with the size of the motor.
Old Jun 5, 2003 | 06:09 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That would depend on where you put the distributor back in.
By itself, stroking a 305 will not "change" the ignition timing. It will certainly change the timing of making your car faster; it will delay it substantially.
Get a "bore kit" instead. You get them at the junkyard, for $100 or less. It magically turns your 3.736" bore into a 4.000" bore while allowing you to use standard, off-the-shelf parts, and requires no grinding or special cams or other expensive or difficult adaptations. You get more inches than you get from the "stroker" kit, i.e. more power, for less money. Forget the 335, it is a bad idea and is just another way for less-informed people to become parted from their $$$$.
In general, an engine's ignition timing requirements follow the cam profile, and the compression ratio. If you modify an engine you will almost always have to change the ignition timing just like you'll have to change the fuel delivery. In a fuel-injected car this is accomplished with computer re-programming, larger injectors, or both. Ignition timing is altered by way of the static setting, or computer programming, or both.
Old Jun 5, 2003 | 06:52 AM
ede's Avatar
ede
bore kit, damn rb you kill me with that
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
Infested
May 22, 2018 11:56 PM
Bryan F
Aug 18, 2015 02:28 PM
