Code 54? Is Haynes right?
Old Sep 18, 2000 | 07:54 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
It's says something about an M/C selonoid (sorry about spelling) and ECM wiring. When I brought my car to one of my relatives (a mechanic) his book said it was something about fuel pump circuitry.
Old Sep 18, 2000 | 08:04 PM
Vader's Avatar
SB,
The error codes are shared among several different engine/fuel system combinations, and therefore have different meanings depending upon which system you have. Soooo, what year/engine/fuel system do you have?
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Sep 18, 2000 | 08:12 PM
rondubbs's Avatar
54. Low voltage at fuel pump OR
Low voltage at Fuel pump relay OR
Output failure at quad driver module
Old Sep 18, 2000 | 09:04 PM
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
It's a 91' bird with the LO3.
Old Sep 18, 2000 | 09:15 PM
Vader's Avatar
SB,
I'm with Ron. Check the fuel pump circuit. The ECM is supposed to get a voltage signal back from the fuel pump power feed on terminal 'B2' at the ECM. It's a tan/white wire from terminal 'A' at the fuel pump relay. If the ECM sees less than 2VDC at this terminal when the fuel pump is supposed to be running, the code will set.
Later,
Vader
"Make Me Bad"
Old Sep 18, 2000 | 09:18 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
hehe. I just got this code. I burnt up the output from the ECM by wiring my heated oxygen sensor on the wrong relay wire. Joy. Time for a new computer
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
tattmann
Sep 27, 2015 05:20 PM
