harmonic damper
Old Jun 5, 2003 | 07:51 AM
Larry's Avatar
Car: 86 Corvette
harmonic damper
I'm building a 350 using a '97 truck vortec motor to replace my '91 305 TPI. Will the 8" harmonic damper on the truck motor clear all the accessories from the 305? And the vortec timing cover is plastic and says "do no reuse" Do after market timing covers have timing tabs that work on both sizes, or do I need a special cover? Thank you for your help.
Old Jun 5, 2003 | 08:11 AM
Vader's Avatar
Only you can answer the clearance question, but my guess is that it should clear.
Cloyes or Miloden (can't remember) has a cover and adjustable tab that should work for you.
Old Jun 5, 2003 | 08:41 AM
Larry's Avatar
Car: 86 Corvette
Anybody try the 8" damper? My motor is in the machine shop and they want the damper so they can balance everything that will be used on the motor. Looks like it should work but very close to the lower radiator hose.
Old Jun 5, 2003 | 04:05 PM
Vader's Avatar
I've run 8" dampers on lower RPM applications with no problems. Adjusting a radiator hose shouldn't stop you.
MoJoe
Sep 15, 2015 12:50 AM
Magman
Sep 13, 2015 12:14 AM
gixxer92
Sep 1, 2015 04:32 PM
Eric2ndGen
Aug 31, 2015 12:33 AM
theshackle
Aug 22, 2015 06:52 PM
