What could the negative effects of this hose being disconnected be?
Old Sep 15, 2000 | 11:19 PM
Mike89GTA's Avatar
I just was looking at my car tonight, checking to see if it was running okay before the Skyline Drive cruise tommorrow when I noticed that one of those hoses that used to go to the EVAP canister had a vacuum. I thought it was just a vent line from the gas tank but I traced it and it goes up to the throttle body. In case you didn't guess, I removed my EVAP canister and just let the hoses hang there. Is it possible that this unmetered air would make my car run poorely? For example pinging? I've been having some serious ping recently and I'm thinking this *might* have something to do with it.
4 bolt 350, 10.4:1 Compression, Edelbrock Aluminum Heads 6085, LT4 Hot Cam /w 1.6 full rollers (Crane), Scat Crank, SLP 1 3/4" Headers, SLP Cold Air Intake, Crane AFPR, 48mm TB, ported plenum, stock runners, Accel Super Ram intake manifold, 95Z #24 injectors, stock fuel rails, T5 Tranny, 3.45s, 9 bolt rear, 4 wheel discs, BFG Comp T/As rear, SZ50s in front, Alston SFCs, ES Trans Mount, ES front A-arm bushings, ES front sway bar end links
Old Sep 16, 2000 | 02:24 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
yes of course, any vacuum leak is NO good! and thats a huge leak!
Old Sep 19, 2000 | 12:49 PM
P J Moran's Avatar
Car: Used to be an '87 IROC
Engine: 5.7l TPI
Axle/Gears: 3:23?
Mine comes off the canister frequently when I'm working under the hood (plug wires, etc). When I go and start the car, and it idles like crap, I know exactly why. That hose fell off again. Yes, you must plug it. I suggest taking the curved hose off at the TB and installing a vacuum cap.
'87 IROC 5.7l TPI - original owner!
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
Damon
Sep 26, 2015 04:29 PM
