Trickle chargers
Car: / 89 IROC /
Trickle chargers
Is it OK to leave a battery on a trckle charger 24/7? I don't think this is an issue but I want ed to post to get other opinions
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Well I could tell you since I know the answer, but since my momma didn't name me "ed", I guess you don't want me to tell you.
J/K!!
Yes it's fine. That's the purpose of a trickle charger.
J/K!!
Car: 89 IrocZ
Engine: L98-ish
You need to make sure the float has a cutoff when the charge is full, otherwise (with cheapo chargers) you can boil all the solution out, make a heck of a mess in the battery box.
an interesting cheapo homade trickle charger is just a regular battery charger the positive end connected to a small lightbulb then to the battery. the negative on the negative terminal as well. i've never had a problem with this setup.
