Temp?!
Old Sep 19, 2000 | 07:39 PM
Slow88RS's Avatar
Temp?!
Okay, my friend has a 89 Form and it runs at around 215 degrees. I think that is normal considering my car runs VERY smooth but runs around 220. Do these cars run at high temps? I have a 160 and drilled a hole in the thermo to allow anti freeze to access the heads before 160. What do your guyz cars run at? BTW, his is bone stock G92 package 350.
90 Iroc G92 LB9
Dual Cats, 3.42 B/W, 5spd, K&N, Homemade Ram Air, TPIS Airfoil, 160 Thermo, Mobil 1 Synthetic Oil, Dexco Anti Freeze
3rd Gen Web Site
Old Sep 19, 2000 | 08:26 PM
Polecat's Avatar
Yep, my brother-in-law has a medium built 355 in a '82 Z28 and it runs 215+ all the time. He's done flex fans, tried electric fans,etc. Next we'll try the new radiator setup and see if that helps.
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,Hypereutectic pistons,9.8:1 compression,HPC Coated RPM intake, Speed Demon 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, K-Motion springs, Comp Cam 1.6 roller rockers, Lunati adv.292/230@.050 with .512 lift,Crane pushrods,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with B&M 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
Old Sep 20, 2000 | 08:59 AM
Brian Shaughnessy's Avatar
Car: '89 Formula
Engine: 355 TPI
Axle/Gears: 3.70 9 bolt.
Both my cars run very normal temps with 180 thermo's and 200/185 hypertech fan switches. On the highway both stay around the 1/4 mark on the guage. GTA only goes up to 220'ish while idling in traffic with the AC on for a long time. The Formula was the 305 until last week and did the same thing... basically as soon as it hit 200, fan came on and cooled it down.
I swapped in the 355 and am using the same stock aluminum radiator and it's running the same temps basically although it heats up quicker I suppose.
I do have factory oil coolers on both.
'89 Formula - Thunderchicken - 355 Vetteheaded TPI/T-5/3.45 9-bolt/black/t-tops - the fun car!
'90 GTA - The GTA - 5.0 LB9/TH700/3.27 9-bolt/black/t-tops/tan leather - the cruiser.
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
