why is my engine spewing oil??
Old Sep 20, 2000 | 08:16 PM
jasons86iroc's Avatar
i just put new seals and gaskets in my engine, it's fine at idle. but when i drive it around the block and come back, my engine is covered in oil from front to back (mostly around the intake manifold). help.
Old Sep 20, 2000 | 08:20 PM
Vader's Avatar
Jason,
Is your PCV system functioning?
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Sep 20, 2000 | 08:22 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
Uhm, this may sound stupid, but did you put valve cover gaskets on? Or at tighten down the valve covers snugly?
Those are the only things I can think of unless pcv valve or tube is clogged causing too much build up in pressure ....
Old Sep 20, 2000 | 08:26 PM
i will go check
ps. i did put gaskets on
Old Sep 20, 2000 | 08:43 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
Just making sure ...
89GTAOz
May 16, 2020 09:31 AM
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
