zz4 305
Old Jun 9, 2003 | 01:03 AM
txhotRS's Avatar
zz4 305
I'm just wondering if ANYONE has tried a zz4 roller cam in a 305.. I mean, I KNOW it'll fit, and work mechanically, but would it be a tiny bit too radical for a 305 ?? has ANYONE had problems with that set-up ?? (the block has been bored .030 over, WITH performance flat-top pistons, ported heads... all that yummy stuff.... in case you need the numbers on the cam... duration @ .50 is 208/221, and lift is .474/.510 with 112 lobe seperation ..
thanks guys
Old Jun 9, 2003 | 03:02 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Re: zz4 305
thanks guys
If you have steep rear gears, like 3.42 or higher, and a stick, and your heads have had the valve guides, etc., clearanced for lift that high then you might get away with it. That IS a lot of cam for a 305, however. Most folks don't go any higher than a Comp XE 262 on the street, which has lift in the .46x region.
Old Jun 9, 2003 | 05:59 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I have a slightly larger cam than that in my 305 (a Comp XR264HR, 212°/218° & .520"/.528" with 1.6 rockers); it passed "enhanced" California emissions inspection like that when I lived out there. So I doubt the ZZ4 would be "too much".
Make sure you have good valve springs (NOT stock - I'd recommend Comp 981, or the equivalent from Lunati, Crane, Ultradyne, etc., not GM or K-Motion) along with the retainers and keepers that go with them.
Old Jun 9, 2003 | 10:17 AM
JR305's Avatar
I ran that cam in my 305 TBI, with world SR torquer heads and edelbrock intake. If you have TBI it will have to be tuned. Before I started burning chips for it the gas mileage was horrible, but it was drivable. If you have TPI I don't think it will need to be tuned all that bad. Their is a guy running the ZZ4 cam with a TPI 305 running mid 13s on the stock chip.
Old Jun 9, 2003 | 10:42 AM
txhotRS's Avatar
well, I have a tbi, DONT WORRY, it has ultimate mods, 1/4 injector spacer, 55 lb injectors, edelbrock performer manifold, major ported heads WITH .600 lift springs, I know I will need a custom chip, .. ANY suggestions, I was leaning towards a guy named BRIAN, he does custom chips for tbi cars from a website called tbichips.com , unless you have an old one, or could make one for me, since you already had that setup in you car
Old Jun 9, 2003 | 01:01 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
I have a .480 lift cam, with 110 lobe sep and 230 duration intake and exhaust in my L69.
Old Jun 9, 2003 | 01:05 PM
txhotRS's Avatar
well, I bought the cam, duration @.050 is 208/221, lift is .474/.510... with 112 lobe seperation... BUT I still need to find a chip,
GouldyGTR
Sep 7, 2015 09:05 PM
buffaloman
Firebirds Wanted
Sep 7, 2015 09:47 AM
buffaloman
Camaros Wanted
Sep 7, 2015 09:46 AM
TBRays98
Sep 6, 2015 05:05 PM
Formula_88AE
Sep 3, 2015 01:47 PM
