A/C delete: Do you need the pulley?
Old Jun 9, 2003 | 04:13 PM
AmorgetRS's Avatar
I looked around and didn't find any real reason... do you really need to get the pulley if the are pulling out the A/C? Will something bad happen if you don't get the pulley?
Thanks,
Douglas
Old Jun 9, 2003 | 07:05 PM
highpower's Avatar
I know on my motor I needed the AC pully even though I removed all of it's componets, the auto tentioner wont work w/o it. I think it was in a either tech article or a post on this site that said just leaving the pully there, for the sake of your auto tentioner will not rob you of any power. And remember, it's our duty to ensure all ford owners are well aquaited with the rear end of our car.:rockon:
Old Jun 9, 2003 | 07:10 PM
AmorgetRS's Avatar
I think I mistated what I was asking. As far as for the engine to work right I know you need something there, I was asking if I could just leave the compressor hooked to nothing instead of having to buy the delete pulley.
My fault.
Douglas
Old Jun 9, 2003 | 07:13 PM
Syxx613's Avatar
Car: 1987 Trans Am GTA
Transmission: 700 R-4
i just removed my AC today and as far as i know it is a good idea to keep the pulley there and hook it up. hope this helps some? if u have any problems just let us know.
Old Jun 9, 2003 | 08:56 PM
MdFormula350's Avatar
you can use the compressor with everything else off from the a/c.
i used the delete pulley to look like a factory job.
Old Jun 9, 2003 | 09:50 PM
AmorgetRS's Avatar
Cool. Any idea why it would make a loud grinding noise?
Old Jun 10, 2003 | 12:17 AM
poorboy8's Avatar
Car: 79 Camaro RS
Engine: 355, carb, alum heads, XE262
Transmission: TH350
I've seen a few fbod owners that got rid of there AC and have a belt just around the tensioner (no ac or smog). Dont remember any exact routing or part#s.
A loud grinding noise is most likely from the bearings on one of your pulleys.
Old Jun 10, 2003 | 10:56 AM
AFatHippo's Avatar
Car: '88 Camaro
Engine: 355
i got rid of the tensioner, smog pump, and ac. just have to buy a belt thats close to the right size, and then swing the alternator to tighten it up. we had to make a custom adjustable bracket for the alternator though. they probably make something you can buy. you can see the front piece of it in this pic:
Old Jan 15, 2005 | 07:13 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
how did you manage to route the belt so it still works properly without something where the tensioner was????? there was someone that found a 6 rib idler pulley that was the same size as the tensioner on the boards but i cant seem to find it now
Old Jan 16, 2005 | 10:14 AM
Damon's Avatar
https://www.thirdgen.org/techbb2/sho...hreadid=274230
Above, is a thread in the TPI section about another way of doing it (no A/C delete pulley needed). Just swapped the pulley on the tensioner for one with ribs (so it can ride on the inside of the belt instead of on the outside) and looped it around the pulley completely bypassing both the A/C and the smog pump.
I though it was pretty inventive, farily clean looking and definitely cheap to do. Owner reports no issues with the setup.
Old Jan 16, 2005 | 10:33 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
yea in fact thats exactly what im doing just need the new tensioner pulley because right now the belt grooves are on the flat of the pulley.
i want to run it like afathippo....
hey afathippo............have you had any problems with belt slippage or anything like that????
and do you konw what sizebelt you needed, i didnt think they made a serp belt that short.
Old Jan 17, 2005 | 11:28 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
double post
Old Jan 17, 2005 | 11:32 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
heres a better shot if anyone else has anything to add about the w.p. contact
Old Jan 18, 2005 | 01:50 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
This just came to my head.
Attached Thumbnails A/C delete: Do you need the pulley?-serp-setup.jpg
Old Jan 18, 2005 | 01:58 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if you leave the AC compressor there, with no lines on it, it doesnt have any oil in it.
the refrigerant also contains the lubricating oil.. without it, the compressor will seize. furthermore, you would have to have the input connected to the output so that the compressor doesnt suck in dirty air.... otherwise, it will start to clog that way too.
Old Jan 18, 2005 | 02:09 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
transam12sec.....that is the exact way im running my belt now. i cut off all the other part of the tensioner acc bracket and am running it exactly as you have drawn. that way it wont hit the upper rad hose. but i have to either get a longer belt or put my smaller underdrive crank pulley on there to see if the belt i have now will be long enough.
but i want to get rid of the pass side bracket and tensioner altogether......will the first belt routing give me enough contact area on the waterpump??? (just like afathippo ran his)
Old Jan 18, 2005 | 07:37 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
I never finished my conversion on the bird. I am however doing it to my truck with the caprice brackets. Why cant you just gut the smog pump and order a belt from a car with no air?
Old Jan 18, 2005 | 10:26 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
well for a while i had the smog pump gutted and you can do that but it will sieze up over time and i (like most people) wanted to clean up the engine bay and get rid of "clutter". thats the main reason i got rid of a/c too
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
anesthes
Sep 30, 2015 07:48 AM
JSDaddy189
Sep 26, 2015 03:50 PM
