Are my wires shot???
Old Jun 9, 2003 | 11:52 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
HI all.
I have measured the resistance of my 3 year old MSD 8mm Heli-Core wires, low resistance conductor (part #3183) and found the following using my digital Multimeter:
Cyl # 1 - 2.68
# 2 - 2.36
# 3 - 2.22
# 4 - 1.71
# 5 - 1.93
# 6 - 2.5
# 7 - 2.09
# 8 - 2.56
Those numbers are in OHMS and the function was set to 20K on my Multimeter.
Does this mean that cyl#1 wire is 26800 ohms or 2680 ohms? I am not sure on this?
Also, if it is 26800 ohms doesn't that mean that the wire is bad?
Thanks.
Old Jun 10, 2003 | 08:13 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Those readings look fine to me.
They're all in the range of 2000 ohms. 2.68k = 2680, etc.
99% of the time, plug wires (other than stock-style carbon-core ones) fail when the insulation wears out, not because of anything to do with their conductivity. Look for damaged insulation, not a change in their resistance.
Old Jun 10, 2003 | 02:44 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
When it's really dark out (no streetlamps), start the engine with the hood open; look for blue sparks jumping out of your wires. (Don't get your hair/clothing/jewelry caught in the fan belts, of course.) If your wires look like a lightening storm, they're shot. Try to keep oil and grease off the wires, that stuff can degrade the insulation over time.
Old Jun 10, 2003 | 04:05 PM
RJR99SS's Avatar
yeah, checking the resistance of a wire dosnt do a whole lot of good. I've seen wires that had no resistance to some that had 30k ohms, it really all depends on the brand.
Like they said, a much better way to determine if you need new wires is just visually inspect them. Some people like to put water in a spray bottle and spray the wires down, if the engine stumbles or something then they know the wire is bad.
Old Jun 10, 2003 | 05:27 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
Thanks guys.
Street Lethal
Apr 30, 2019 12:14 PM
Glowsock
Jan 9, 2017 04:06 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
