What is the best Head CC for a 383???
Old Sep 21, 2000 | 03:20 AM
Metallica383's Avatar
I want the best head that GM makes for a 383 that will give me at lest 320 Hp maybe more?
Old Sep 21, 2000 | 07:01 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
get a vortec. A vortec 383 will make 350 hp with all but the mildest cam.
Old Sep 21, 2000 | 02:55 PM
lock's Avatar
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
CHP built a 383 with Trick Flow 23* heads and got over 400 hp with ease. They are 64 cc.
Mark Lock
- 86 IROC-Z - My car, mods and ET's
- -= IROC Online =- - The site dedicated to the IROC-Z
[This message has been edited by lock (edited September 21, 2000).]
Old Sep 21, 2000 | 08:38 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
A 67cc head with a 9.1cc head gasket and a .015 inch deck height will make 10.25:1 with flat-top pistons.
A 64cc head would be better suited to an engine with a .030 inch deck height. I've heard good things about the Iron Eagle heads, as far as flow-ability versus cost, as well. you can use ANY SB intake on it, versus the Vortechs which require a special intake.
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines,
5-point racing harness, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Speed-sensitive steering conversion, underdrive pulleys, Crane Hi-6 & more. 1.05g skidpad verified.
New best E/T! 14.400 at 98.6 MPH in 88 degree air at Stanton, Michigan.
Old Sep 21, 2000 | 11:43 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
best head gm makes for that is the fast burn. at that hp range a simple 882 will cut it though.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Mickeyruder
Sep 2, 2015 02:45 PM
gixxer92
Sep 1, 2015 04:32 PM
bdads
Aug 24, 2015 06:01 PM
86White_T/A305
Aug 17, 2015 12:16 AM
