can't get it running again? wtf!?
Old Jun 11, 2003 | 04:33 PM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
O.K. here's my problem... My engine is turning over but not firing, I've got a good spark and I know I'm getting fuel. Every once in a while I'll get a little backfire through the carb but it won't start, the car was running about a month or so ago, and I havent touched it since then. The motor is a 305 with a holley 600 1850 and a vac. advance distributor. I thought it might be 180 off or something so I turned the thing 180 the other way and now makes farting sounds, lol... can any of you help me?
Old Jun 11, 2003 | 05:42 PM
dans82bird's Avatar
Engine: 302
i've been thinking, could my fuel not be atomizing correctly due to blockage? I rebuilt the carb about 5 months ago and maybe its clogged from old fuel and debris... i did run it w/o a filter a few times *DOH*... or maybe my timing chain is off/stretched but it doesn't sound like it
Old Jun 11, 2003 | 07:37 PM
TransAmTBI's Avatar
Engine: 305 TBI
Transmission: th700R4
if your defanately getting fuel and spark then check the carb.. idont know much about carbs but arent there a couple of screws hat change fuel and air mixtres? you say you rebuilt it right? well try that, put in a new fuel filter if it isnt new already and reset the distributer ( crank engine to tbc, and face rotor twards #1 cylinder)
Old Jun 12, 2003 | 12:17 PM
dans82bird's Avatar
Engine: 302
ttt
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
