Starting Problems
Old Jun 11, 2003 | 11:11 PM
mr7dblzero's Avatar
Starting Problems
Will a heat shield or a heat wrap around my stater help out Heat Soak. Sometimes when my stater gets hot when I turn off the engine and restart it the engine will not turn over until the engine cools down?
Old Jun 11, 2003 | 11:23 PM
85z28cmro's Avatar
It sounds like your starter may be going. That was also the case with my car. When the engine was hot, I had to crank it hard before it would start. The starter eventually stopped working all together. Is this the only one the car has had? If so, it may be time to replace it.
Old Jun 11, 2003 | 11:25 PM
89rocs's Avatar
Car: '89 IROC
Engine: 5.7lt 350 TPI
Transmission: Original :(
When your trying to start the car, does it do anything? click?
I second the opinion on the starter going south.
Old Jun 12, 2003 | 11:47 PM
mr7dblzero's Avatar
Starting Problem
Nothing happen's no click nothing. It doesn't do anything at all.
Old Jun 13, 2003 | 12:29 AM
89rocs's Avatar
Car: '89 IROC
How long has it been since the starter was replaced? You might want to go ahead and get that done if it's been awhile
Old Jun 13, 2003 | 09:56 PM
prOject-IrOc's Avatar
Car: 1990 Iroc-Z
if it's an auto, try wiggling the gear shifter while you turn the key. sometimes the nuetral safety switch won't get a good connection when it gets hot. if that fixes it, jus pull up your middle console and replace it. $20 at the zone.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
