Could G-Tech be right?????
Guest
Posts: n/a
Could G-Tech be right????? I have friends who doubt it. I recently got a G-Tech to test out the new mods on my '89 IROC L03.
All I have done is added K&N Open air, Hooker Cat-Back with direct fit Catco Cat and an MSD Ignition coil. With the correct weight of 3500lbs entered, G-Tech Pro reports 235HP. I have not done 1\4 mile times yet. I got this reading at 105MPH while in Drive(instead of OD) going up Rt.75.
I just thought I would check with you folks to see what ya'll think. Any input is appreciated. Thanks.
Car: 99 Formula
Axle/Gears: 342
I think that's way off, that is supposed to be RWHP correct? that makes it even more rediculous.
The 1/4 times are fairly accurate when used correctly.
Car: 04 GTO
Transmission: M12 T56
When set up right they are fairly accurate. When not they are junk. If it told you that you had that much power you either a.) put in a way heavy estimate of your weight and/or b.) were running downhill.
Guest
Posts: n/a
Thanks for the replies folks. I thought it was a little high. I was thinking that my car was about 3500lbs. Maybe it's a little less.
I used this method: GVWR 4195 - RC 700 = 3495lbs. (700 being recommended capacity for our cars, or so I thought). Oh well, looks like a Weigh Station trip is in order. Thanks.
Andy
I used this method: GVWR 4195 - RC 700 = 3495lbs. (700 being recommended capacity for our cars, or so I thought). Oh well, looks like a Weigh Station trip is in order. Thanks.Andy
