Should I buy Straight Plug or Angle Plug heads?
Old Sep 22, 2000 | 07:47 AM
CrossfireCamaro's Avatar
Wich will work better with SLPs headers, or dose it matter?
Old Sep 22, 2000 | 08:13 AM
Brian Shaughnessy's Avatar
Car: '89 Formula
Engine: 355 TPI
Axle/Gears: 3.70 9 bolt.
Go pick up a Sept. 2000 copy of GM High Tech Performance. Nice article on heads in there. General consensus is angle plugs provide better plug location and most of the good heads flowtested in the article are angle plugs.
As for SLP headers... no problem with 90 degree set of plug wires. In fact it's probably easier changing plugs on most of them to change by just using a wrench from above than the socket from below.
'89 Formula - Thunderchicken - 355 Vette L98/T-5/3.45 9-bolt/black/t-tops - the fun car!
'90 GTA - The GTA - 5.0 LB9/TH700/3.27 9-bolt/black/t-tops/tan leather - the cruiser.
Old Sep 22, 2000 | 11:26 AM
Great, looks like ill use the angled. Thanks for the info.
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Feb 28, 2016 03:33 PM
CRFred
Feb 7, 2016 11:39 PM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
