Banging Noise
Old Jun 12, 2003 | 01:06 PM
Strunthopht's Avatar
Banging Noise
When I'm in 2nd gear, floor it, I hear a bang and then when I let go of the throttle, I hear another bang..
same thing if I'm in 3rd gear doing 35-45 MPH, I get that clanking noise..
I know it's not the tranny mount, I just replaced it with an aftermarket.. thx
Old Jun 12, 2003 | 01:46 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
torque arm mount broken? That will swing up and hit the floor when you punch it. Probably worthwile to get down there and take a look at everything, including motor mounts as well.
Old Jun 12, 2003 | 02:57 PM
Vader's Avatar
Excellent advice.
While you're under there, make sure you include the rear trans mount, crossmember bolts, cat converter/exhaust clearance, LCA mounts at both ends, transmission bolts, and torque converter/flexplate or flywheel bolts.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Randomtask2
Sep 7, 2015 05:06 PM
