code 32!!
Old Sep 22, 2000 | 03:35 PM
86IROCZ's Avatar
code 32!!
I need some help with this one. I only get code 32 after the A/C is on. It never comes on when the A/C is off. It also only happens some of the time. Does anyone why this could happen (isn't 32 the EGR?)
thanks
Old Sep 22, 2000 | 04:00 PM
84IROC's Avatar
You may have a small vacuume leak that only affects the EGR operation when there is an extra load placed on the engine such as with the AC engaged.
Also have you replaced the cam with one that causes a lower than normal vacuume signal? Not sure if this would cause the prob you describe but is worth checking out. EGR system needs about 10 inches of vacuume to operate correctly BTW.
"84Z28/'91 305TPI comp cam flowmaster TB coolant bypass/shutoff valve to heater core MAT relocated Ram-Air(home-made) gutted air-box IROC ground effects/wheels GY245/50's 700R4 superior shift kit/ corvette servo(excellent shift kit BTW) Rebuilt engine and transplanted it myself. Love this engine!
LOW performance people should drive low performance vehicles!
[This message has been edited by 84IROC (edited September 22, 2000).]
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
