pedal is getting stuck
Old Sep 21, 2000 | 11:01 PM
silvermelon's Avatar
anything past halfway and the pedal stays down when i let off. what with that?
thanks
Old Sep 21, 2000 | 11:08 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
The obvious.......Throttle return spring??
You didn't say if it was carbed or F.I.
The not so obvious......I've recently seen a third gen that the floor mats were bunched up by the pedal.
Pedal would stick about half way down.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am, flowmaster,FRA,Pro Kit,BMR STB, polished calipers.
1986 Chevy 3/4 ton pick up,flowmasters,4.10s,
1981 corvette FOR SALE
1995 ZX6R,Yosh,D207s
GO #3
Old Sep 21, 2000 | 11:52 PM
IROC-ZTWENTYGR8
Guest
Posts: n/a
What engine do u have and does it stay down if u floor it??
Old Sep 22, 2000 | 12:37 AM
lg4, and yeah. id have to sorta hit it hard to get it to stay. basically, if i go farther than halfway, and i dont go real slow and gentle like, it stays down.
Old Sep 22, 2000 | 04:23 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
man i had the same problem with mine, that was scary as hell, i got a modified 305/5 speed i floored it and that puppy revved, i had to slam it again to get it back, i checked my throttle return spring and everything but it doesnt do it anymore, i sprayed some carb cleaner on all the linkage and the cable
86 Camaro with 88 305 LB9 converted to carb, edelbrock performer manifold, S/R Torquer Heads, Hedman Headers, Crane Compucam 2032 edelbrock cat-back, gutted cat, slp underdrive pulley, mallory ignition, 305 h.o dual snorkel air cleaner, hypertech thermomaster chip,160 degree thermo, and fan switch, 5-speed, 3.23 posi
95 Beretta Z26, 3100 V6, 4 Speed auto, stock
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
tmellott89
Oct 14, 2015 02:06 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
ironbmt
Sep 27, 2015 06:00 AM
