żGasket?
Old Jun 12, 2003 | 04:59 PM
Vader's Avatar
żGasket?
What is the compressed thickness of a FelPro 7733-PT2? 0.021"?
Old Jun 12, 2003 | 10:49 PM
Guest
Guest
Posts: n/a
IIRC thats the factory replacement 350 head gasket? If so, its .039 like everything else Fel-Pro sells.
Old Jun 12, 2003 | 11:06 PM
Vader's Avatar
O.K. I was hoping it might be a different size, like the FelPro:
-P/N----BORE----THICK
1003----4.166----0.041
1004----4.190----0.041
1044----4.200----0.051
1034----4.200----0.041
1094----4.100----0.015
1014----4.200----0.039
But it is listed as the factory replacement, so it's probably the 4.100/.039".
Old Jun 14, 2003 | 10:11 AM
Guest
Guest
Posts: n/a
Those are the 'performance' gaskets, if you want to call them that.
I have a set at home, I can measure them if you really want. I know though that their stock replacement SBC stuff is the blue no retorque standard issue .039 compressed. I might even be able to dig up a Fel Pro spec book.
Old Jun 14, 2003 | 08:10 PM
Vader's Avatar
Max,
Thanks, but don't waste any extra time. That should be close enough for what I'm doing. I could find data on the "performance" gaskets, but not the "standards". I just wanted to make sure it wasn't like the GM factory 0.021" gasket for the L81.
db057
Jan 10, 2020 08:55 PM
sheachopper
Jul 31, 2019 11:27 AM
TP355Z
Exterior Parts Wanted
Oct 21, 2015 01:05 AM
Jonas Earl
Sep 27, 2015 07:39 AM
hdis2002
Sep 8, 2015 02:52 PM
