does Mobil 1 make a Dexron III synthetic?
Old Jun 14, 2003 | 09:54 PM
breathment's Avatar
all the Mobil 1 tranny fluid we carry at autozone is ATF. and im in need of changing the tranny fluid in my Truck (2002 S-10 4.3) and i wanted to put in some Mobil 1 if they make a Dexron III fluid..
Old Jun 14, 2003 | 09:58 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Forgive me, but I can't figure it out, that makes no sense at all.
There is both an auto trans fluid and a gear lube (manual trans) from Mobil 1. What is it you're looking for?
Old Jun 14, 2003 | 10:01 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
after researching the tranny board, I regret buying Mobil 1 ATF, seems the quality isn't the same as their oil.
Old Jun 14, 2003 | 10:03 PM
breathment's Avatar
ok, "Mobil 1 ATF" . thats all it says on the front.. should of made myself more clear , will it work with trannys that require Dexron 3?
Old Jun 14, 2003 | 10:14 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I could be wrong, but AFAIK the Mobil1 ATF meets the Dex 3 spec.
Attached Thumbnails does Mobil 1 make a Dexron III synthetic?-mobil1-bottles.jpg
Old Jun 14, 2003 | 10:16 PM
breathment's Avatar
thanks RB. im not to knowledgable on tranny fluids and such and all the requirements so i wanted to make sure. thanks!:hail:
Old Jun 14, 2003 | 11:07 PM
Z_Ghost's Avatar
I change my trans fluid once a year and have been running Mobil 1 for the last 4 years now.
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Orr89RocZ
Oct 7, 2015 12:47 PM
New2Chevy
Oct 4, 2015 11:27 PM
JHX
Sep 21, 2015 08:53 PM
