emissions and error codes
Old Sep 23, 2000 | 03:54 AM
84camaroz28's Avatar
Having trouble passing emissions and getting
a check engine light.The car is a stock
84z28 5.0 L69 with 48k miles.The error code
is "32" and can happen most any time.Also
the choke light flickers off and on with
a muted electric buzzer type noise when it
does.This also occurs randomly.Any help
would be greatly appreciated.
Old Sep 23, 2000 | 09:38 PM
Vader's Avatar
84,
A '32' is a failing atmosheruc pressure sensor (BARO sensor). That's the rectangular black sensor attached to the firewall that apparently isn't connected to anything. It should have had a little foam cube filter on the vent fitting, but that's probably long gone. Check the electrical connector at the sensor. Meter the sensor to make sure the resistance between terminals 'B' and 'C' is not zero. Make sure that a vacuum hose hasn't inadvertently been connected to the vent nipple.
Your CHOKE warning light and alarm may be related to the BARO problem.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Sep 24, 2000 | 06:05 PM
Thanks for the response Vader.I will check
the sensor tomorrow,my meters battery is dead.I noticed today that now I am also
getting error codes 41 and 42.Seems like there are many causes for those codes
according to the manual.Are there problems
that are common to cause these new codes?
thanks
Old Sep 24, 2000 | 06:27 PM
Vader's Avatar
84,
Both the '41' and '42' are related to failures of the EST circuit. Your distributor is not getting reference pulses to the ECM (41) and the ECM detects a problem with the HEI (amplifier/switch) module in the distributor (42). You may want to take a close look at the connections at the distributor and ESC module on the firewall.
Later,
Vader
"Make Me Bad"
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
3rdgenparts
Sep 28, 2015 10:47 PM
mfp189
Sep 27, 2015 09:25 AM
