Having problems, please help...
Old Sep 25, 2000 | 12:21 AM
IROC-JP's Avatar
The first thing bugging me is my brakes. The pads are about a year old and have plenty of of material left, but every now and then when I apply the braks I hear a metallic squeal like the metal warning tab hitting the rotor. However I check the waring tab and it is far away from the rotor. But I did notice that after only 50 miles after I washed my car the front rims were near black from brake dust. And when ever I start going from a stop my car seems jerk ever so slightly like the brakes are slightly on. And when I took my front rims off and turned the rotor there seemed to be some fricion with the brake pad.
Any suggestions?
Also my voltage gauge drops down to 8 or 9 volts every now and then, and sometimes wavers around 12 when it should be at 14. I took the alternator and the battery to a shop and they both tested out perfectly. So is the gauge messed up or what?
Thanx for bearing through this long post,
Jason
305 TPI
Edelbrock headers, highflow cat, borla cat-back exhaust, AFPR, modified MAF,
Stage 2 chip, 1.6 ratio roller tip rockers, b&m megashifter
Old Sep 25, 2000 | 11:41 AM
84IROC's Avatar
Disc brakes will drag slightly so do not worry bout that. As for the metallic scrapping you here have you looked the rear brakes? My voltage gauge does the same thing on my 84 Z28(16 year lod car but was not driven for 10 years). A lot of peices have rotted or just gotten dirty from lack of use. This particular prob I believe can be traced to a bad ground behind the dash. I am planning on looking into it one of these days and I will post the results.
"84Z28/'91 305TPI comp cam flowmaster TB coolant bypass/shutoff valve to heater core MAT relocated Ram-Air(home-made) gutted air-box IROC ground effects/wheels GY245/50's 700R4 superior shift kit/ corvette servo(excellent shift kit BTW) Rebuilt engine and transplanted it myself. Love this engine!
LOW performance people should drive low performance vehicles!
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
